- Oct 9, 2003
- Phoenix. YOUR HAIR IS GOOD TO EAT
This chair rocks.
I saw this http://www.dack.com/misc/aeron.html
and got a little bit worried, well, nonsense. Either they were being completely overdramatic or the chair has been revisioned extensively.
The pellicle is not rough at all, it almost feels like fishing wire, not at all coarse or abrasive.
The lumbar support is excellent and does a job.
The adjustments are excellent, I can adjust all sorts of things I didn't even really know about, they aren't that hard to adjust AT ALL. You can adjust the armrests while sitting down.
I really like the tilt limiter, the chair will tilt back like most chairs, but this one you can decide how far back you want the chair to lean, sometimes a chair will tend to lean too far back, or be too hard to get leaning, this solves all that.
I would not get the basic, only the fully adjustable, totally worth it. I didn't get the posturefit, but I might.
I paid $500+80 for the chair from www.allaboutyouroffice.com These chairs are slightly used.(I noticed a tiny thread of the seat part sticking out) but for 33% off, it's absolutely worth it.
I recommend this chair for everyone!
