after fitting a pelt
spiritedandy
Premium Member
Middlesbrough
hi all
after fitting a peltier to my water system ........seti driver will no longer run .....(not sure why that is !!!)
ive deleted and reinstalled it .....but when i goto set up...
spy opens with the driver .........then the driver quits ends prog ...
with the spy still running .....
im useing clc and been running fine until i added the pelt ???? makes no sence !
no seti :confused: :cry: :cry: :cry:
EDIT baisic i cant get the driver to run ....it just turns off ....
found out why
hi all
i have solved th problem it must have been the tec .....
if you double click on spy / client / configure / client control....
it then says stop client when cpu reaches xx degrees....
i just stoped this..........and all is well ......puter reading 5c now .......
everything ok now running seti again :D :D :D :rolleyes:
that is strange, how low was the temperature setting for when to turn off seti? or was it just a bug in the software that came out due to the low temps?
