After installing H50, loud whining p/p fans noise & higher-than-expected temps?
My system specs:
i7 930
Asus P6T SE
Antec 900 (semi-modded)
Antec TruePower 650W
2x Gentle Typhoon AP-15 fans for push-pull
Hey everyone. After an extremely frustrating install that was full of questions and head-scratches, I have finally set up my first aftermarket cooling system: the Corsair H50 (at least, I think so!). However, there are two things that I believe are not normal or maybe what I think is definitely not right. I have been analyzing what may be the fault or solution:
1) There is a loud whining/blowing/idling fan noise that is coming from the 2 GT AP-15 push-pull fans. I originally set my fan+radiator assembly as an intake that looks something like this:
*Rear of case*Fan>>H50Radiator>>Fan*Front of case*
However, there is a loud sound in which I am not sure why the fans are making the sound. It almost sounds like some sort of pressure going on. I have double checked the direction of the fans, and indeed the fans look and seem like they're blowing air INTO the case (hence, intake). Although when I place my hands on the back of the fans, I can feel some slight air blowing too. Actually, when I put my hands behind the back of the supposed direction of ANY case fans, it seems I can feel some air as well. I guess this is just normal--nevertheless, I am 100% sure the p/p fans are in the right direction.
What I think may be wrong:
1a) AP-15 fans malfunctioning? (though I highly doubt this)
1b) Radiator malfunctioning?
1c) Perhaps I need some kind of shroom/grommet or some vibration-control or some washers in between the fans/radiator? Or something wrong with my screw placements? I've used 8 screws in all of same size and same washer size (as recommended by the Corsair YT & How-To vids). They're screwed in very tightly, too! However, I have heard many similar setups with my case/fan/H50/other hardware combinations without any problems. :-(
2) The other thing I noticed is when I booted up my system, the temps look a little off with the H50. After just viewing what my idle is in the MB & in Windows, they seem to be somewhere around 30-35 degrees at stock 2.8 GHz. I expected to be better. My ambient room temperature is cool. I understand that stock temperatures do not mean anything, but I was hoping something in the range of 22-28 at stock, given I am using the already-applied Shin-Etsu TIM paste that comes with H50 over my previous stock HSF/stock paste. I have not tested the CPU at a true load, but it seems to be jumping around 40-45 at 15%+ load when I tested it briefly in Windows via the Core Temp program. Fans and pump are installed correctly and it seems they're running at full speed.
What I may think could be attributing to this (if this is indeed not normal):
2a) I mentioned previously in my other posts that there were imperfections on my TIM paste when I bought the H50 pump. I was re-assured that this would be okay. It looked like there was some unevenness on the outer edges. No biggie. Unfortunately, I was also having a difficult time installing the Prior to getting the pump onto the bracket, I had smeared some of the TIM paste onto the outer edge of the CPU. I had attempted at least 10 times before I could push the actual pump and lock it into its bracket. However, I had smeared some already on the CPU. Please see pics here: http://img38.imageshack.us/img38/1663/pumpp.jpg (pump) & http://img829.imageshack.us/img829/4831/cpuil.jpg (cpu)
This is what it looked like. A well 30+ minutes after this happened, I finally got the pump into its place. I may or may not have smeared more as I locked it into place. Do you think I should clean/reset the pump/CPU with my own thermal paste? (I only got some MX-2 at this moment). Or do you think it would have been okay? I guess I was concerned for either air bubbles or just imperfections in the paste creating a terrible contact (although it was on the OUTER edge), etc.
2b) Browsing through the Corsair forums, the other thing I could think of was either a defective H50 pump
2c) Or maybe I am not locking the pump/bracket into place enough, or the screws were too tight. Or something similar.
2d) I also DID NOT use the ADHESIVE PADS. Maybe is it possible the adhesive gives more space for the screws to work? (someone said it may act like a washer mod?) Thus, the bracket/pump did not situate itself correctly?
Any suggestions? Thank you all for your help!
My system specs:
i7 930
Asus P6T SE
