- Dec 18, 2000
Is there a way to wipe out all references to older NVidia cards in the registry? That's all I know that may fix the below problem.
For some reason i can't get my VisionTek GeForce3 to install correctly in Win2k (and yes, it's an actual retail copy of Win2k). When I first put the GF3 in it installed itself automaticly when windows started (or so I thought). After playing through a few games I noticed something was odd... after a while I figured out that there was absolutely NO hardware anti-aliasing (I didn't even have any mipmaps). I didn't notice this at first since I was running such high resolutions. I tried changing settings using both the GeForce Tweak Utility and Display Properties. The only things I could do were change the clock speed (which I had to do manually every time windows started, even though the "Apply Settings at Startup" box was checked) and change the FSAA quality (which seemed to drop my framerate while not actually anti-aliasing anything at all).
After this I uninstalled the card... it installed itself on reboot and had the same problems. After some testing I figured out it was installing the Win98 drivers...WTF? It WILL NOT accept the Win2k drivers. It says they do not contain information about my hardware. I've tried every method of installing the card, but none work. The driver version is 12.0 reference driver (came on the cd), but it wouldn't accept the 12.2 drivers either.
The only thing I can think of is that something from my old GeForce256 is messing it up in the registry. Anyone have any ideas or suggestions?
-=mac=-
-=mac=-
