AGOIA 1700+ for $125
[:) :) :)] I'm so stoked right now I finally got my AGOIA hooked up to water and its soaring @1.76=11.5x153 this is at default voltage settings the bios actually shows the voltage from 1.79-1.81. Stable in Prime the chip will actually boot and run alot faster but its only stable here. I also just received another AGOIA 1600+ exactly the same Green packaging and Green Core (the core looks sweet) [/:) :) :)]
Just Got Mine XP1700 AGOIA......
Just picked my XP1700 AGOIA at a local dealer,his last one for the night. Anyways my question is there anyone with any results on this stepping and on the following day code 0209...? I'm really anxious to ignite this little rocket......!!!! I will be navigating this with a KR7A-RAID and fueling with some Samsung 2x256mb PC2100 DDR. Hope this combination of hardware will pull it off.
SOUPNAZI
prices are dropping too! 87 bucks for a 1600xp
did that xp 1700 at 1.76 pass prime yet?
Mine are both
AGOIA0208
Y...
Year 02 Week 08...
What is the letter or number in the first spot on the 3rd line?
What CORE.....?
jbslow could you explain what you mean by what core is your core ....?
Thanks
SOUPNAZI
Colour....
The ceramic is a brown and the core is a like a light purple-gray colour....Any good...? jbslow
Thanks
I dont know what or if the color makes a difference I just thought these green ones were kewl. Be sure to let us know how it overclocks.
I don't know if it just me, but it seems like voltages between 1.775 and 1.85 don't make much difference on these AGOIAs.
at 162 FSB and 1.775 volts, it craps out while loading windows, and the same thing happens even at 1.85 volts. It has to be the CPU since the unlocked t-bird in the same configuration had no problems at those speeds.
check this out. Over 100 MHZ OC @ 1.65 Vcore :)
I can probably go higher too, but I haven't tried yet,, it's getting late and I have to go to sleep :p
This is the funnest stepping that I have ever experimented with. It's just too hot to go higher for some reason, but that will be solved next week.
