Actually I think the main difference is the pro has extra pins for cards that may take more power. I do not think this is used in cards yet. I am not sure if it will become the standard in the newer, higher power vid cards. The 4X card does not have the extra pins but I am pretty sure it is backwards compliant with 1X,2X. I just wanted to know the forums opinion on how much of a factor it should be when upgrading to a new mobo. Thanks for your reply.
"Thank you for your support" - Bartels and James
