- Sep 13, 2001
- Valparaiso, Indiana
Well first I just have to say never work on your pc when your too tired!Tonight I decided I would check the voltage on my oem 8500.I checked the core volts and then went to the ram to check it and I slipped and shorted 2 points out,that was all it took to kill it,there was a little circuit trace burnt in half and the pc would give me the beep that there was no vid card so I fixed the trace and now it posts but there are just a bunch of lines on the screen,its dead
and so now im using an old pci card.Im going to go pick up a new one tommarrow at best buy and I have the choice of a retail 64mb 8500 or a retail 128mb 8500/le at the same price.For you hardcore video guys which one do you think I should get.I read that the retail 128 le's are at 250 so I dont have to worry about getting stuck with a 230.Need some help deciding,thanks.
