What the hell did I do!?!? I was applying some changes in my BIOS using directions provided with my Mushkin PC133 Rev3 ram to speed up the ram, and i'm all done and I reboot my machine and nothing comes up on the screen anymore! No post, no video, no nothing....
So I figured, "Okay I overheat the chip" and let it cool down a few hours.... come back try to fire it back up and it still won't post and no video...
I checked the temprature of the chip before rebooting and it was at 39C / 102F .... is that too hot?! I was under the impression 39C was pretty good with the few of you having problems with your CPU touching 50C and such...
So did I fry my CPU or something? I don't see how that would be possible...
Here's what I'm using:
Thunderbird 1.1 ghz
Mushkin Rev3 PC133 128 stick
KT7-RAID Mobo
GeForce2 GTS 32MB
Do I have to reset the BIOS or something using a jumper on the motherboard!? I couldn't find anything in the motherboard's manual about this...
any ideas or help would be greatly appreciate... I hope I didn't shove $230+ US dollars down the drain...
Jay
Thunderbird 1.1 ghz
KT7-RAID Mobo
GeForce2 GTS 32MB
Jay
