air 240?
caddi daddi
Godzilla to ant hills
so which way are you supposed to sit an air 240???????
I took my little air 240 rig to the shop and one of the guys noticed that the "side" of the case is marked for the feet that come with it.
if I moved the feet to there, the clear side would be the top and the psu wound be drawing air from the bottom.
which way do you set yours?
caddi daddi
caddi daddi
I have a little mini itx board in mine and you had better plan on your cables before you start.
with everything jambed up into the corner I had to use a pair of needle nosed pliers to align the cpu power and a stick to bludgeon it in.
if I put the little feets over where the marks are and set it up that way all the little front panel icons would be sideways........
