- Jun 21, 2002
While most people like to have air flowing through the case from the bottom front to the tomp rear. The credit of this idea should partially go to RetroUO as he thought of doing this. At first i told him it was a silly idea and if it was any good other people would be doing it.
The Idea: Mount 2 or 4 12cm case fans to the side of the computer, these fans dont need to put out alot of airflow. These would be positioned so that the fans are hitting the CPU HSF, Mosfets, Video Card, ram, NB, and SB and the majority of the mobo. All other fan holes (front and back) would be used as exhaust. Now as i understand it, turbulance, or air striking the surface is important. Thats why a fan goes on the CPU, the air strikes the metal and somehow absorbs more heat. So why not have air striking the entire motherboard. Then the exhaust fans would get the air out. The case would have somewhat pressure and moderate noise if i designed it in a manner that would have quiet intake fans at about 40-50 CFM and moderate 30 DB exhaust fans which would hit about 30 CFM each. The case would have more exhaust fans because of a top blow hole (probly 120mm) and the PSU even if it were a dragon like mine and had 2 80mm ins and 2 80mm outs.
How would this work? The fans on the side would have to be low rotational speed or else the panel would turn into a big speaker vibrating. Rubber grommets would also be used since the structure would be so much reduced and prone to vibration.
