- Sep 7, 2003
I was looking up air compressors for dusting purposes, then I had the idea of using air compressors instead of fans. I don't mean for widespread use, just as an experiment. I wonder if having one, two, or even three of them in a system would do anything if they were in just the right spot.
http://cgi.ebay.com/ebaymotors/12V-...014QQitemZ330233629111QQrdZ1QQsspagenameZWDVW
The above runs off of 12v, and can take up to 10 amps, so a dedicated PSU may be required, especially if you had a few of them.
You could keep a fan blowing over the whole heatsink... But maybe you could fix a few of these to blow on certain areas like the base of the heatsink, or across the whole heatpipe, and have one for each heatpipe.
My thought is that having a few very high airflow areas would be superior to even a high CFM fan.
I'm just wondering if anyone has ever tried it just for fun, and if they did, if they were able to make a "superior" setup. I would think air compressors would not want to go 24/7 like fans do.
Just curious.
Just curious.
