Air conditioning unit
YardPig
I got this air conditioning unit kicking around. approx 2x2x1/2 foot. Any idea's?
I highly suggest NOT using it unless you can cover everything inside your case to prevent ANY condensation. Water BAAAAD for components. But otherwise it would be really suhweet! Remember, your heatsink can only be as cold as the air around it.
Close...your heatsink can only be as cold as the DEWPOINT of the air around it. Dewpoint varies with temperature and humidity. As long as you aren't at or below the dewpoint, condensation isn't an issue.
Man you're so lucky you could submerge it in antifreeze/water mix and chill a peltier down to insane temps :). That's what i've been wanting to do :). Well just my two cents.
-dasouthernocer
