- Dec 21, 2001
- Copenhagen, Denmark
Thinking of experimenting with a chiller setup, I need to air cool a 80+W pelt, what heatsink do you guys suggest I should use??
Starfox said:tell me how this turns out, im very interested in a HSF cooled
pelt system.
Yodums said:PS: Only 80watts right? 80watt+ shouldn't be cooled with air.
Strangelove said:Yep read it allreadyI think I'm going with a Swiftech MCXc370BLA and then ducting a 120mm 100+ CFM fan to blow air over it. It's a lot cheaper than it's bigger brother but should do the trick, what do you think??
I might build the chiller big enough to fit two pelts on it, if I can find enough money. That way I will need two MCXc370BLA's, and I'll duct the 120mm fan over both of them. Should prove interesting!!
maskedgeek said:if your tryin to make a chiller out of a waterblock and a pelt, dont do it, beacause it doesnt work, but it can be done if you do it rite..
the problem with using a waterblock is the surface area, i did a expirament with a heatercore and stuck it in the bitter cold outside of minnesota then went and ran water thru it... BRRRRR! very cold!
so id say get multiple swifties and multiple pelts and mount them on a huge cold plate and mount that on a heatercore with the fins flatened out so they are level with the tubes..... im gonna do this in like 2 weeks with my modded heatercore(makin another) and my svc goldengate and an 80 or 72watt pelt
Strangelove said:Thinking of experimenting with a chiller setup, I need to air cool a 80+W pelt, what heatsink do you guys suggest I should use??
