- Oct 31, 2002
I have to say, this has been a fun road to better temps and i do not belive i am even close to being at the end of it. although, I can say that i acheived some very nice temps without resorting to water, peltier cooling systems. All it took, was a couple case fans, a thermal right sk7 and some light duct making.
we see here the the all assembled box with my cpu fan ducting that sucks air straight from out the back. this allows me to run 1.8 ghz on my xp 1600+ without running case open, ie not drowning the house in noise thanks to thermal takes's smart fan II.
The speed controll is taped to the top so i can kill the noise if i so wish.
a close up of my 2 80 mm ducted feeds. these move a total of 60 cfm through the duct into the cpu fan. this creates a slight vaccum, which helps a fair bit as my external ducting is almost completly passive.
my sk7 heat sink
the sk7 using a smaller amd fan. this works... well. but i decided to go for more impressive numbers than noise reduction. i now have a big peice of alluminum ducting out my window feeding my case...
I compared my two radeons here. on the left, my working, currently used 128 mb 8500 with crystal orb fan. on the right, my now purely ornimental 64 mb radeon 8500.
finally, with the last month of time, i can acheive this idle temp.
http://ev0one.idleplay.net/comppics/octemp.jpg (screenshot)
On load, i run 38º c and it continues to get colder. with my aluminum ducting out side the case, i suck air in right from out side, using a 80 mm case fan and a air filter.
the temp outside when i took this was 9ºC and its going down as its almost winter. ill post back when it gets -40 out there which is what we can expect from the calgary winter.
my sk7 heat sink
