Air flow on CPU
usa_eddieo
I just bought a boxed PIII 1Ghz CPU with heatsink & fan. The fan blows down onto the heatsink! Shouldn't the fan pull the heat away from the heatsink and CPU?
The A+ for Dummies (me) Book says so and so does an I.T. tech I work with. Am I killing my CPU or not?
Thanks,
usa_eddieO:cool:
usa_eddieO... I have a PIII also (500) see below... and have dual Antec cooling fans on them blowing ON THE CPU!!! Some people do say to have them sucking hot air away from the CPU, However, I feel the best way would be to forcefully "Cool" the CPU by having the fan blow towards it .... Just my advise and what I found the be the "general" recommendation...
Oh, BTW..... Seems like sometimes these fans are designed this way from the factory.....probably for a good reason.....
:cool:
The best thing to do is to experiment and find out which way is best for your situation.
The recommended method however is to have the fan blowing on the cpu. The reasoning behind this is that the tips of your cooling fins are cooler than the bottoms, which are closest to the heat source.
As the air travels down the fins it can continue to pick up heat and remove it from the heat sink, because the temp of the hs is hotter as the air moves down.
If the fan is sucking, then the air comes into contact with the hottest part of the hs first, and then moves up to the cooler regions of the hs. As the air approachs the cooler areas of the hs, it can be almost as hot as the hs itself, so it will then lose the ability to pick up heat and remove it.
I have read however, that for whatever reason, sucking the air up on certain hs/fan combos, will improve the cooling abilitys of the hs.
Here is a link to a write up on the dynamics of cooling, originally posted by hoot.
You should read the whole article, which you will find here the first link is a short cut to the answer for your question.
Hope this helps.
HSs are usually built to have the air breath in a certain direction. Im sure if your running just a non OCed 1gig, you should be able to flip the fan and see what your better results are.
On most of my previous HS they blew the air in.
By the way what HS is it?
The stock Intel HSF's are designed to have air blown on them. They exaust the hot air on either side of the heatsink because of the way the fins are oriented. Only one of my three systems has air being drawn away from the heatsink. The two others have air being blown on them.
Most heatsinks are designed to have the air blown down into the sink. I had the fan on my SK6 installed in "suck" mode at first and it was running about 5C hotter until I flipped it down to blow on the heatsink.
The HS was supplied w/the cpu by Intel. Its a large & aluminum. Will that silver grease help with heat. While playing high graphics games (UT) the heat goes to 75F.
Also, I don't know how to flip the fins on the fan. Is it possible?
Thanks for your help!
usa_eddieO
usa_eddieO
75F or 75C ??? if your at 75C then thats way too hot :eek: You should be able to just flip the fan and it will push the air in the opposite direction..... Yes the silver thermal paste WILL help a little.. I would get some of the new Arctic Silver III compound which may even bring you down a few more deg's!! You can get at most online places including Newegg... Since you play a lot of high graphic games, I would recommend a better HSF than the factory one... Check with Newegg or whoever you prefer and see which HSF's they offer... Good Luck ...
75 F isnt even bad and if your playing a game like UT then, Hey even better!
If you said 75C then that means your comp should probably sizzling right now.
The first you might want to just reseat it. I dont necessarily think that Artic Silver is really needed but just try out your silver stuff and see if it makes a difference.
Well afterall of that if your still worried about it and dont want to go out and buy a HS then just lap your HS.
Then New Egg
tip for the future when your report your tempspeople usually go by C or they report both
