- Jan 31, 2002
- Out looking for ET... in IL, USA
Air Flow & Fan Placement
I just got done reading an article that talks about two fans going out is better than one going in and one out. I have always though my setup was pretty good. i have the bottom blow in with the card helping direct the air upward then the second fan on the bottom up on an old HS to push the air up then an exhaus fan on the top in back. puss my 92mm CPU fan. is this the best way ore should i move the bottom or front fan around. i like the front one there because i spent all the time to remove all the steal casing infront of it. well here is a pic of what i though the flow would be like and it seems good to me. If it is suggested to move it i will give it a try.
