- Oct 13, 2002
I have a bit of a problem...When leak testing the waterblock(Gemini high flow spiral), radiator and via aqua (submerged)it was working fine with about 4ft of tubing. Now that I have the bay res I can't figure out how to get the air out of the tubes (the res is filled to max) There is 6.5ft of tubing plus the length inside the radiator and other parts. How sould I go about getting the air out of the tubes? Should I shorten the length of the tubes?
The inside of the radiator is about 1 Ft, and the res is a Bay-res
