- Mar 7, 2004
- Los Angeles
Okay, with the build date for my new rig fast approaching, it's about time to organize my new watercooling setup and plan what I want.
I'll start with my goals for the system, based on my previous watercooling experience. My previous config was a polarflo TT chrome, 120.3, and a 50z.
Do's:
1) High performance, I want to be able to really see the performance boost from my setup this time.
2) 1/2" ID. Simply put.
3) Easy Monitoring, I'm thinking flow rate and water temp monitored through a 7" LCD on the front of the case, should work quite well.
4) Clean, organized, and well done.
5) Cool the GPU
6) Show it off
Don'ts:
1) Attempt to use food coloring as water dye
2) Use antifreeze which clouds up system tubing
3) Use cheap tubing
4) Have everything just haphazardly strewn about the case, make it look nice.
With that in mind, I'm designing my system more efficiently this time, for maximum performance as well as silence. The case this time is the Silverstone TJ07, selected for not only it's looks but the cooling capabilities. The idea here is to have a majority of the heat produced by the system dealt with in the bottom section of the case, thereby allowing the rest of the case a constant supply of cold air and keeping the actual components cold. So the radiator, pumps (yes, this is meant to be plural), and PSU will be kept in the bottom of the case.
Okay, component time.
CPU Block: Swiftech STORM $80
GPU Block: DangerDen 8800GTX Full Cover $115 or AquaXtreme MP-01 $45
Radiator: Thermochill PA120.3 $134.99
Reservoir: Undecided
Pumps: 2x DDC-12V Rev2 "Plus" Pumps $75 each with 2x Petra's Tech Shop Delrin Tops $30 each
Tubing: Tygon 3603 Tubing 1/2" ID 3/4" OD $2.80
Fans: 8x Arctic Cooling AF12025 $8
TIM: Ceramique $8
Anyway, any comments/suggestions?
7
Do's:
5) Cool the GPU
6) Show it off
Don'ts:
3) Use cheap tubing
TIM: Ceramique $8
7
