- Feb 2, 2001
- Delray Beach FL
Still just looking at WC (except for my first minor try using the AquariusII). One surprise was radiators at the bottom front of the case, which is what the AII does, and I have also seen it in pics of other setups. It would seem that such a design moves hot air from the radiator INTO the case. That is, unless the airflow is reversed from typical aircooling and the bottom front is exhausting air. In that case, the fan(s) in the back of the case must be blowing in. Except the PSU, which must always be blowing out. That would seem to split the air moving into the case, some going out the PSU, some going out the front. Nothing much cools the drives?
The best solution I guess is getting the radiator completely out of the case or at least on the upper back of the case so that airflow is normal. Do I have this right?
