- Feb 2, 2001
I've just bought this card hoping to achieve the high overclocks others reported with the Turbo series from Albatron.
The first thing that struck me was the temperature of the videocard after a few rounds of 3DMark01, at stock speeds I couldn't keep a finger for more than 5-10 seconds on the back of the GPU, the memory was moderately warm but there was lots of heating at the back end of the card (the PCB is longer, Ti4600 style and the voltage regulators and other power circuitry is near the back of the card)
I put some huge fan blowing air into my computer and decided to try some overclocking: the GPU craps out at 275 and the memory seems to have the breaking point between 610 and 625 (where it gets really hot), I will do more tests to see the memory's limit but anyway this seems pretty low for 3.3 ns DDR (I haven't checked under the heatsinks, do you think this could be slower memory?)
So today I lapped the GPU, it took me close to two hours using 350 and then 1000 grit sandpaper. Unfortunately this didn't make any difference, I was able to run 3DMark at 275MHz only once after that I've tried again and same old story, freezing at 275, running fine at 270. Seeing that I've lapped a Coolermaster sk A heatsink, and attached to it two long screws - I'll try to replace the card's seemingly inefficient copper cooler with this, see if I'll be able to hit 300...
The thing that concerns me the most is the heat on the back-end of the card, the capacitors there get warm enough to get me worried... Has anyone experienced this problem with a Ti4200 (or 4600 better said, as this card has Ti4600 layout)? Should I put a fan under the card blowing air at the power circuits?
