- Mar 25, 2001
went shopping for a water block,
found one at my local hobby store , it is a stamped
copper resevoir that soldered together.
about 1 x 1 inch square with two fuel line fittings
the perfect water block (thin copper).
#2) one man is using a scrapped water-cooled head
off a old two-cycle model boat engine with two line
connectors, also a perfect water block.
he stated that with alcohol cooling his temperature at
idle is -37C and it goes no higher than +5c with
a lot of multi tasking .
excellent if you ask me.
that is how i will be setting up my cooling system.
very cheap cost.
david.
very cheap cost.
david.
