i was looking to make a water cooled system on a 1.2/200 k7 and a MSI KT7 Pro 2-A motherboard. Can any of you list possible GOOD solutions for under $150 USD
Hey Acid,
I have mostly DangerDen stuff, I also have the MSI pro2a mobo and if you want you can check out my watercooling setup here http://yourpage.blazenet.net/nutndun/watercool.htm I believe I have about $200 into it with the pump. Works pretty good, I need a little more case ventilation but even with the way it is now I have my T-bird 1Ghz @ 1300 w/1.95vcore and the case temps are up to 27C and at full load crunching Folding WU's the cpu temp is at 44C. You can see in the pics there isn't much of a way until I add some more case fans for the fan to pull too much air through the radiator with the case covers on. Hopefully this info helps ya a little bit.
Always try water first with a Bird or Duron. Pelts won't give you as much as water. Another pimp for DangerDen. You should be able to put a top notch H2O rig together for $150.
The kit was $120.00 and came with everything except for a fan for the radiator. I was running hot 130 F at full load on my T-Bird before. Tonight I have been running the same programs and I havn't seen it go over 100 F. Also I couldn't get the Bird to stableize over 1100 with HSF but it is cranking at 1200 @ 1.75v easy. Take the plunge It's worth it.
