- May 15, 2001
Ok, the same guy that told me My older IDE drives would not be stable on the KTA Raid board also said that I HAD TO have an "ATX" rated Tower or Case to put the new KTA board into.
Is this more garbage?
I currently have a full sized tower. 21/2 ft tall, same length. Looks like there is ample space in there. I imagine the screw holes won't match up because my other MOBO is pentium based. But I am pretty good a "rigging" stuff. Couldn't it be MADE to work? I am just trying to avoid spending any more money than I have to. Also, I am probably NOT going to OC much. I might (might) take a 750 tbird to around 900mhz. the tower is going to sit under a desk, out of view. I can drill thousands of "air holes" to eleviate the heat IF OCing raises the temp that much to be dangerous.
Ok, I am all ears. And one more thing........since I am probably NOT going to OC at all......I won't be needing any extra fans, diesel engines, or jet propulsion coolers like you guys need. Currently I have a 200watt power supply. Right now that is handling everything I need. If I am not going to OC, do I REALLY need a higher wattage? I don't know that the KTA/ (or E) needs any thing specific to run. Does it? It may REQUIRE a 300 watt deal, I don't know. Enlighten me.
You guys are the best. I have learned a lot in two days. help me here and I think I am home free. Thanks
