alpha heatsinks
BK
does any one know where i could buy an alpha SB series, LS series, W series, WS series, S series, or F series or similar heatsink. these are their general heatsinks not the ones desined specifically for certian cpus. Since they don't sell factory direct online any more i don't know where else to buy them. Most sites that sell other alpha heatsinks such as the pal6035 and the pep66 do not sell any other alpha heatsinks like i am looking for. Does anyone know of any alternatives to these that are of similar and of the same quality made by a different company? I need one any where from 45 to 100 mm square (70mm x 70mm square would be optimal) or one that could be cut down to size for an extreme cooling project i am going to under take. any advice or comments would be welcome. I am also looking for a online company that sells square aluminum tubing in metric sizes in small quantities.
Many specialty machine shops will custom make alpha-like coolers at reasonable cost, so you might try having one made localy.
