Alpha PEP66T and Peltier
heavenly
I would like to now if the Alpha PEP66t i capable of dumping the heat from a PIII800EB@1002mhz The tec is a 80 watt . I am using a "tunnel" to get the heat blowing direct out of the case so no buildup of hot air comes inside the case. The alpha can suck air that is at ambient temperature by using a fan in the front panel with a little more cfm than the fan on the tec. Any other suggestions??
As you can see in the post above this one i have figured it out !! The PEP66T is capable of dumping so much heat . This thing rocks !!
