- Mar 25, 2001
there seems to be a problem regarding water cooling
in peltiers.
you are using the wrong heat transfer agent.
you should be using isoprophyl alcohol which is 5 times better at transferring heat any object
how you say!
simple! by using a model aircraft fuel pump which is
built to withstand nitro-methane(the fuel itself)
and alcohol. (continuous duty of course)
along with an inline radiator to the water block or after
the water block to drain into a large plastic resevoir
(to prevent static ignition of alcohol.
dumb founded?
test! use alcohol in one container and water in the
other container let acclimate to room temperature.
pour water on hand or arm, then alcohol , which is
colder. used this setup before very effecient!
[img="http://"]descriptiondescription
[order=1]
[#]text
[#]text
[#]text
[/order][3][/3]
in peltiers.
how you say!
dumb founded?
[order=1]
[#]text
[#]text
[#]text
[/order][3][/3]
