Aluminium PC Case Cutting
Klasse
Hey All
My First Post is on a MONSTER HTPC BUILD
First of all the case is a ORIGINEA st21 HTPC (pic below) and basically need the left side of the case drilled out either with a Mesh design cutout with a laser or 3 cutouts with mesh covering if you know what i mean so i can mount a EK-CoolStream SE 360 (Slim Triple) on the inside left of the case with Screw mounts (like thump Screws) links and pictures below , i will also need the top cut out an INCH from each side and fitted with Plexiglas on top CAN ANYONE RECOMMEND A LASER CUTTING COMPANY THAT WILL DO THIS WORK FOR ME ???
https://www.ekwb.com/shop/ek-coolstream-se-360-slim-triple
Johan45
You'll likely have to do the leg work locally. Look for a machine shop in your area that has the tools and time to do what you want. Probably won't be cheap either. Could you not find a case more suited to what you want?
