- May 18, 2008
Ive been thinking lately about fan placement. Ive got a xclio case. i know every body hates them BUT! mine is modified and i feel it makes it a much better case with the mods Ive done. I'm almost done with it all, I just need to find some powerful 140mm fans, which i haven't found yet (100cfm each would be nice), and cut some holes in the top of my case for exhaust. first off, people always say that the rear fan in a case should be used as exhaust, well i just don't get it. 1 heat rises. so the exhaust fan should be nearest the top, like the antec 900. 2 when you have a cpu heat sink that has a fan blowing down onto the cpu and other components near by, why would you wont a fan very close to it sucking air out of the case? wouldn't the 2 fans fight for air in that space? any way here are the pics of my case.
1. every body knows what they look like but i though i take a pic any way. 1 thing though its a big case! probably not the biggest but its got plenty of space for me.
2.this next one is the first thing i modified. I took the hdd cages out cause 1 they totally kill the air flow of the front fan and 2 i didn't need like 6hdd slots. So i drill out about 12-14 rivets and pop the hdd cage comes out. great air flow now!. my hdd is now mounted in one of the internal A drive slots that i don't use.
3. the next mod i did was just for the hell of it. the front fan is so big that it doesn't even fit in the case so what xclio did was just make little unfuctional scoops on the side to cover up the gap left buy the front fan. well what i did was to cut out the front of the scoop here
and then cut a nice big hole on the side panel to kind of funnel more air into the case. does it work don't know but at least the scoops are functional now .
4. the last mod I've done so far was the easiest. i flipped the power supply upside down so it would suck air through the vent on the top of the case. the only way i could mount my psu was the 120mm fan was facing down pulling the air away from the cpu. so i cut 2 notches out of the mounting plate that mounts to psu and flipped it upside down and screwed the mounting plate with the psu attached to the case. the notches were cut because the plate hit the support bars that attach to the 5.25 drive bays. sorry its a horrid pic!
