Am I doing good folding?
jonspd
Super Speedy Senior
I have been folding stead almost 24/7 probably like 24/5 sence 2 weeks this tuesday I'am in 1075th for team 32 and have obly been folding for about a week and a half.
jonspd
jonspd
Super Speedy Senior
Well yes I only have one rig the one in my sig but I did do one WU with another rig just to see if the WU's would change in my folding on my pc.
portorock
Quantico, Va but am from Queens, NY
Just makes sure that you are using the flags as they force [email protected] to use optimizations while foldign=much faster folding=more points. If you're not sure, you can make a shortcut to the proggy on your desktop and go to properties. After the quotation mark in the target field put the following...(space)-advmethods (space) -forceasm. Then drag that shortcut into you startup folder in the start menu. That's it. It should look like this
"C:\[email protected]\fah3console.exe" -advmethods -forceasm
The proggy is substituted for whatever you have it called
jonspd
jonspd
Super Speedy Senior
"C:\Utilities\Folding @ Home\winFAH.exe" -advmethods -forceasm
Thats the target property for my folding is that correct?
shortcut property
Milkman
NH Biodiesel master
Yup, that's right, do just like portorock says and add the shortcut to your startup folder, I did this about a week ago and have gotten nothing but high point Gromacs and boy do they add up fast!!
jonspd
jonspd
Super Speedy Senior
I would but funny thing is that they add one for you when you install the proggy in which I have deleted due to the fact that I need my cpu sometimes for 3dmark, etc etc so I'am not going to have my cpu @ 100% when I first start I will run the proggy but once I hit 500th place I'll be happy hopefully thats possible with one system.
