- Apr 20, 2009
Is this a good enthusiast desktop?
Well, even though I don't plan on buying my PC till June'ish. I still would like your input if im headed in the right direction, and making sure im not leaving anything out. I also want it to be pretty future proof/upgradeable, and AMD will be supporting their 800 series chipset on AM3 so it seems like decent bet.
Target Budget is < 2000$ CANADIAN for the tower.
Does this look tempting ->
CPU: AMD Phenom II X4 955 Black Edition Quad Core
CPU COOLING: Zalman CNPS9700NT Copper CPU Heatsink 110MM Fan
GPU: XFX Radeon HD 4890 1GB 850MHZ 1GB 3.9GHZ GDDR5 PCI-E
RAM:2X Corsair XMS3 DHX TW3X4G1600C9DHX 4GB 2X2GB PC3-12800 DDR3-1600 CL9-9-9-24
HD: Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM
MOBO: ASUS M4A79T Deluxe AM3 ATX DDR3 790FX 4PCI-E16 2PCI SATA2 eSATA Motherboard
CD DRIVE: Samsung SH-S223Q/BEBS 22X DVD+-RW SATA DVD Writer Black Lightscribe OEM
PSU: Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan
CASE: Azza Solano 1000 Black ATX Mid Tower Case 10X5.25 1X3.5 8X3.5INT 2X230MM LED Fans & Window No PSU
So its,
AMD Phenom II X4 955BE @ 3.2Ghz
8GB DDR3 RAM
1TB HD
*How much difference would i see between,
9-9-9-24 and 7-7-7-20 and 8-8-8-24. Would it be noticeable?.
So that comes to $1660'ish. So with the left over I guess get another HD. Or save for ATI 5000 series GPU, also I guess we will add a extra 100$ish for Vista X64. And of course a couple dollars for the *Good* thermal paste.
So how does this look, did I do well? Or am I making a mess?
So its,
8GB DDR3 RAM
1TB HD
