I am probably asking something that is already been asked and covered. But I may not know exactly the terminology in the answers given. I am attempting an over clock on an AMD
5000 , base is 2600 MHz. I read the sticky labeled easy as 123. I get through the HT fine and it maxes out at about 1450 MHz.
To my knowledge the formula for this is reference x HT Multi. When I proceed to do the memory I lock the memory at 1 to 1. To my knowledge this means that I would need to run my
reference clock to 400 MHz to make my memory run at 800. It says in the sticky you would be ok starting at your base memory clock. Could someone help me with this step and also the formula of the reference and the cpu multiplier to get the actual memory speed. I will list my specs below.
AMD AM2 5000 @2600 MHz
Foxcon C51XEM2AA motherboard
Corsair XMS2 Pro 6400 memory 800 Mhz 4-4-4-12 timing
2 gig
Dual 7800 GT SLI configuration
Zalman CNPS9500 Heatsink
OCZ GameXtreme 700 watt power supply
2 gig
