Hi im REAL need of help im completly unexperienced with fans and stuff like that. im going to buy an oem 1.1 or 1.2 processor( if i get the 1.1 i plan on overclocking to 1.2) I ordered the 1.2 retail a long time ago but the idiots have been delaying it and it was suppose to ship tomorrow and now its not going to till 2/21(this is the 3rd delay) The fans im thinking of are the fop38(i havent seen specs or anything but i always here about this thing any links to it?) or a super orb i found on www.3dcool.com this fan seems pretty pwerful(i dont know anything about fans im just comparing) but here are the spec for the orb:
other socket CPUs as well
Designed and tested for overclockers
Designed for Socket Thunderbird CPUs, works with
Top fan 5000RPM (17CFM), bottom fan 5500RPM (25.4CFM)
32dbA/34dbA fans
3-pin Power Connector for monitoring
Ball-Bearing for superior life!
Aluminum Alloy 6063 Heatsink for FAST heat dissipation
Comes with thermal compound
Lifetime Warranty
Now if it will work great but i dont know how measuring volume works but this has a volume of 32dbA/34dbA (there are two fans) Is this really loud and annoying? If some of u think i should just be safe and get the 1.1retail then tell me any suggestons would be great
Ps if u need to know about my case, its at coolerstar.com they only have 1 400watt midtower thats mine
32dbA/34dbA fans
Lifetime Warranty
