- Oct 18, 2018
- SEOUL,KOREA
HI guys! i'm oc'ing my 3700x ryzen cpu via asus x470 prime pro mobo. testing by prime95 small FFT, max heat mode.
my rig spec is this :
amd 3700x cpu with 240mm aio (frostflow 240 x, arctic p12 fans)
samsung c-die d4 mem 8gb x2
asus x470 prime pro with vrm airflow via arctic p12
antec eag pro 750w psu
his rx570 vga
i changed uefi settings like this :
llc auto
vrm phase control extreme mode(full phase active), 110%
soc phase optimize.
soc 1.13v
dram 1.36v
vcore 1.337v
pbo disable
fclk 1866
other things are auto.
when i put 4.2ghz in this setting, then shutdown when i run prime95.
so i put 4.1ghz and this core voltage (1.34v cpu-z says.) works fine until now when runs prime95 or x265 encoding.
i think cpu temps and vcore voltage are quite high. i'm using open case, and room temp 27'C(80'F) now.
should i oc in lower voltage and clock? or is it fine to use 24/7 ?
i need your opinion. thanks for reading or advise and sorry for my bad english..
thanks to all of your advise, i changed like this :
soc auto
vrm phase asus optimal
dram 3733 cl18-21-21-40
for now, cpu temps are 85'C(185'F) when running prime95, still temps quite high but everything works fine
his rx570 vga
llc auto
soc phase optimize.
soc 1.13v
dram 1.36v
vcore 1.337v
pbo disable
fclk 1866
soc auto
