- Mar 5, 2001
- Dillsburg, PA, USA
Ok, I am getting really frustrated with this. I know this to be one of the best motherboards out there but right now I am ready to set dynamite to it!
What is happening is in order to get my PC to boot, I literally have to UNPLUG my PC every time, wait thirty seconds and plug it back in and then hit power. Then it boots fine. If I don't do that, all the fans come on, the HD spins, the other drives initiate but the monitor does not come out of sleep mode...
Allow me to tell you what ABIT has suggested and what I have done:
[order=1]
[#]Try a different monitor - DONE - Tried three different monitors (varying in size from 15" - 19")
[#]Try a different video card - DONE - tried an older TNT2 Ultra AGP card, tried a Voodoo 5500 AGP video card, and tried a Voodoo 4500 PCI video card
[#]Get A Sparkle PS - DONE - Do they get commission for selling these?! Didn't make any difference...
[#]Try A Different Processor - DONE - WTF? Where did this come from? I tried a Duron 800 MHz, T-Bird 850 MHz (mine) and a T-Bird 1.33 GHz 266 FSB (my friends)
[#]Take everything out but the video card - DONE - no change in status
[#]Reset CMOS - DONE - The way the ABIT tech told me to do it was leave PS plugged into both wall and computer, switch the jumper, wait 5 seconds and switch it back. Did NOTHING!
[#]Try Different RAM - DONE - Ended up dishing out serious cash for this DAMN Crucial RAM
[#]Defective MoBo - DONE - Swapped it at the computer shop for a brand spanking new one, same problems.
[/order=1]
Now here comes the kicker, I borrowed my buddies IWill KA-266 MoBo with 128 DDR RAM and hooked everything up on my system. Guess what? It worked fine. So I went to a local computer shop and tried it with the IWill KK-266 (I think that was the model #) with all of my equipment including my RAM. Worked perfectly.
Called ABIT back and then they blamed all my problems on putting an IWill MoBo in my case because it, and I quote, "Causes serious corruptions in the case as well as the power supply". Has this company ever heard of actually helping a customer? They told me that there was basically nothing else I can do and just live with it.
UPDATED - I just tried to boot it again. I am ready to destroy this damn motherboard. I moved my PC, and now I cannot get it to boot AGAIN! Just like the suggestions say, it lights up and everything appears to be fine (fans spin, drives seek) but nothing will bring the monitor out of stand by. I tried two different monitors, two different AGP video cards, a PCI video card, I reset CMOS (including pulling and replacing the CMOS battery), and everything else. ABIT is absolutely no help, I check to insure that there was no metal to metal contacts with the motherboard mounting (even went so far to use ground isolating rubber grommets). My PS is the SPARKLE 300W which is exactly what ABIT recommends. Is this board a piece of crap or what?
Anyone else got any other suggestions?! Please help.
__________________
Thank You!
Keith O. McKeever, Jr.
Generic Mid Tower Case
Sparkle 300W Power Supply w/ 2 High RPM case fans & 1 PCI card cooler
Abit KT7A MoBo
AMD T-Bird 850 MHz 200 FSB Processor w/ GlobalWIN FOP-38 Cooler
768 MB CAS 2 Crucial RAM (1x512 MB, 1x256 MB)
Maxtor DiamondMax 45.0 GB 7200 RPM UATA-100 Hard Drive
Samsung 52X CD-ROM Drive
Hewlett-Packard 9350i 10/8/32X CD-RW Drive
Jaton GeForce 2 MX 32 MB AGP Video Card
Creative Labs SoundBlaster Live! Gamer 5.1 PCI Sound Card
LinkSys 10/100 PCI Ethernet Card w/ WOL
AOpen 56K v.90 K56Flex PCI Modem Card
[order=1]
[/order=1]
__________________
Thank You!
Abit KT7A MoBo
