AMD Athlon 1.4ghz Mobo??
Inferno
To all the mobo and overclocker wizards out there.... I need a good mobo that will support an AMD 1.4ghz chip. I have heard both Asus and Abit are good mobo's but, I need to know what the best is. Lend me your knowledge and please let me know what the best mobo for the AMD 1.4ghz chip would be.
Thx
Inferno
Everyone has a prefrence, it does not mean that one mobo is better than another, I would suggest looking at reviews and seeing what people use in this forum as a indication of reasonable mobo's. I personally like my Abit KT7A-Raid and recomend it to everyone as not only has it obtained great reviews but it is widely used and respected in these forums.
It would be very advisable to go for a DDR board at this point. SDRAM is pretty much on the way out now. All of the fabs in Taiwan are making it for the sake of making it right now and selling it at a loss. That's a long story for another day - but that's the way it is right now.
Give it a few months and SDRAM will be a very expensive commodity like EDO is right now. Go for DDR.
Yeah, after reading the Babelfish translation of that Epox 8KHA review (the revised KT266 chipset) I think DDR is here..... it's like I've always said, wait and see what Via has to offer in DDR before you buy.... they wont disappoint. (not for real long, at least)
SickBoy
If you want stability and flexibility, check this one out.
Asus A7A266 DDR Socket A ALI M1647 200/266 FSB ATX MB
Socket A AMD Athlon/Duron processors to 1.5+GHz
Chipset: ALi M1647 North Bridge and ALi M1535D+ South Bridge
200/266MHz Front Side Bus
2 unbuffered DIMMs with up to 2GB of PC1600/PC2100 DDR SDRAM
3 unbuffered DIMMs with up to 3GB of PC133 SDRAM
AGP Pro slot
5 PCI slots, 6 USB ports, 2 Serial and 1 Parallel ports
ATA/100
ATX Form Factor
asusa7a266$159.00
I hope that helps.
The A7A266 is 1) based on the Ali chipset which is not as fast as the competition; and 2) not on AMD's recommended list for the 1.4.
The AMD 760 north bridge is by far the best chip for the Athlon (although the upcoming SiS could be a challenger, it's reportedly based on AMD's core). With Crucial's rock-bottom PC2100 DDR prices, there is NO reason to buy a slower KT133A board any more.
Buy a board that is not on AMD's recommended list at your peril... remember what happened with the big power-supply debacle. I've tried boards not on the list and had very poor luck (e.g. MSI 6341 K7 Master, Asus A7M266, both poor boards in my experience, although some claim success using them).
There are 2 AMD 760 boards on the recommended list: the FIC AD11 and the Gigabyte GA-7DX. I have both of these boards, they are both equally, fabulously, stable. I'm typing on the GA-7DX system right now, with an Athlon 1.4; I just ran an Uptime check in Win2K and I've been running for 12 days, 3 hours, 57 minutes and 3 seconds :) That's with constant use of not just internet and office apps, but Nero, Counterstrike, Serious Sam, Asheron's Call, Quake3, Unreal Tournament, Anarchy Online Beta4 (with constant client crashes that don't crash the OS), ST Voyager Elite Force, etc. Suffice to say the GA-7DX is one SERIOUSLY STABLE board. Beware of others who use the word "stable" to mean "POSTs and runs the benchmark". Anyone who plays AC, EQ, AO, UO knows that to crash is to lose a week's work... for online RPGing, you need genuine stability.
The one drawback to the GA-7DX, especially for those in this forum? No multiplier selection. It only supports FSB-based overclocking (although it does so with a neat on-the-fly Windows-based soft FSB overclocking utility that works great in Win2K).
My test box uses the FIC AD11, and I have to say, not only is this board equally stable as the GA-7DX, it also overclocks farther, even if compared strictly FSB-to-FSB overclocking-wise. Its power supply is nicely spec'd, with my NC Silverado air cooling, an Athlon 1.33 runs rock solid at 1536. With my Swiftech MCW462-based water cooling setup (no TEC) I can boot Win2K and seem to run fine at up to 1610, although it fails after extended runs of 3DMark 2001.
I have nothing but raves about the FIC AD11, if it has any downside at all, it's that the heatsink fit is a little tighter than some boards, there are a few capacitors around the socket area. Nowhere near as bad as, say, an Epox 8KTA3, and someone I know actually got a Swiftech MC462 to fit an AD11 (with slight Dremel work). The Silverado fits just fine, and that's all that matters to me, especially at that aforementioned rock-solid 1536 :)
So, to summarize:
- FIC AD11, wonderful all-around
- Gigabyte GA-7DX, also wonderful if you plan to only FSB overclock
- Avoid boards not on AMD's list
- Stick to AMD 760 north bridge
- You're still running Win9x? STOP IT. BAD dog.
KC
I happen to love my non recommended slow than the competition ASUS A7A266. It's fast enough to do anything I ask it to, and with Win2k I haven't had one....single....error yet.
It overclocks to 1330 (1.1 (200) reg chip speed with PC100 RAM)
I have noticed on the FIC AD11 that it has built in sound. Will that affect the motherboard any like the old ISA slots do? I plan on buying a sound card, so would it be better to get a mobo that does not have the sound already built in? Or does it matter at all?
Also, I am looking at the Asus a7a266 mobo. Does it support up to 1.4ghz? The stats says it supports up to 1.2+ghz, does that mean 1.4 or what?? Please let me know!!
I'm building a system on the 1.4 right now, and the best I found was the GA-7DXR. It has everything on the 7DX, but with the addition of a 3rd DDR slot for a total capacity 3 Gb, and it does support multiplier changes, but they may require jumpers being set on the board physically. All the other changes can apparently be done through "EasyTune," their Windows-based proprietary O/C software. I haven't got the board yet, but I've been studying the manual. I'll say more about it when I've got it if the information is requested.
