amd Athlon 3200+
Sykotix420
hey guys im a newbie when it comes to OC...but ive seen it done many many times and ive toyed around with the settings in my bios a bit..but i havnt really done anything drastic..all im wondering is what settings should i use to get about 2.5 - 2.6 out of my AMD Athlon 64 3200+ venice core
my mobo is a Gigabyte GA-K8N-SLI, ive only got a a gig of RAM but whatever...if anyone could gimme sum advice id appreciate it..ive got CPU-Z and Everest on here so if you wanna know any temps or voltages lemme know an i will post em thanks!
JimOkc
Howdy!
#1. Take a few minutes and read this http://www.overclockers.com/forums/showthread.php?t=391768
remember terminolgy inside the bios may be different but as an A64 it all will help in the long run.
#2 get the tools mentioned. cpuz you have, a good temp monitoring proggy, and something to test stability (prime 95, OCCT, orthos).
(edit #2a) Get your bios settings off of the auto settings especially for voltages (CPU, DIMM), multi, bus ref clock (similar to old FSB), memory ratio and timings.
#3 use the basic steps mentioned in post to allow you to test your components separately.
#4 Let us know how it goes, and have fun doing it.
Sykotix420
Sykotix420
thanks guys...i will give it a shot...i noticed that everest way over calculates my temp..it says its running at like 69*C but my bios says its only at like 32*-33*C which is closer to bein correct? the bios?
