- Dec 24, 2005
- Portland, Maine USA
Hi I have a few questions about my cpu. My system is as follows:
_________________________________________________________________
MSI K7N2G-ILSR nforce2 supports cpu's at 333MHz or lower
AMD Athlon XP 2400+ (266Mhz)
512MB single channel spectek pc 2700 (333Mhz) ram----mobo set to 1:1 RAM to cpu ratio
Decent 300W power supply
ATI Sapphire 256MB 9600pro
Thermaltake Volcano 8 cools up to an AMD Athlon XP 2800+ (don't known if they mean T-bred or Barton 2800+...)
With my motherboard I am able to change the FSB freely. The default for my cpu is 133Mhz. Currently it is set to 147Mhz and the core speed of the processor is 2205Mhz. Currently PC Alert4 reports that my cpu temperature is 43 degrees celsius, and I am running 5 IE explorer windows and windows media player. My questions are as follows:
1. What is the Athlon XP equivalent of my clock speed?
2. Is my temperature good?
3. What is my multiplier? I would guess it's 15? because 147 x 15 = 2205MHz
4. How come my motherboard doesn't like it when I go up to 166Mhz FSB? I am guessing it is because the multiplier is too high. or too low?
5. My voltage is default. Should I change it? How much should I increase it And if I do will it harm my CPU with the current cooling I have?
Thanks in advance,
Joe
Thanks in advance,
Joe
