I unlocked my AMD 2500+ Barton to a AMD Mobile Athlon XP-M(Model 10) by connecting last 2 bridges on L5 (change it to Mobile M), cutting bridges on L6 (get max mutiplier of 15X). and cutting bridges on L8 and L11 for Voltage starup and max voltage. I used Abit Nf7 - S ver2 with BIOS 21. I am still can not get Xp to see it as a Mobile AMD to use the POWERNOW in AMD mobile CPU without it I am still can not change the multipier on the fly.
Anyone with same mobo and get it work please run WPCREDIT to get a copy of the HOST BRIDGE setting to get it work ...
The new UNLOCK barton is running at 180Mhz x 11 at 1.5V(MOBO) which equal to 1.275V(Mobile) stable with all torture tests I thrown at it (47C idle and 54C full load)
Here is a frew pictures of it
THANKS
THANKS
