As the title suggests I am looking for guidance on an AMD build. I was a long time AMD user and then when Intel Skylake came out, moved to the dark side. Well it's time for a new partial build, meaning CPU, motherboard, and RAM, PSU isn't needed but not out of the question. Budget sits, currently, at $1,400.00 USD. My preference is start with later gen, so I'd prefer 5000 series AMD over 3000. Motherboard should be ATX to fit the Corsair Airflow 540 predecessor (same design without vertical front drive bays). I'm in southern US, so an AiO of either 360 or 280 is desired (360 front mount, 280 top mount). If suggesting a MB, please note I am using two full length M.2's.
Where I am starting is as follows:
AMD 5800x - https://www.newegg.com/amd-ryzen-7-5800x/p/N82E16819113665
ASUS Crosshair Hero - https://www.newegg.com/asus-rog-crosshair-viii-hero/p/N82E16813119110
GSKill DDR4-3600 - https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232863
Arctic Cooler AiO - https://www.newegg.com/arctic-cooling-liquid-freezer-ii-280-liquid-cooling-system/p/N82E16835186248
GPU is a 2060 Super which is sufficient for my Gaming needs (2560 x 1440 @ 1080p).
PSU is a Corsair 750 bought at time of build.
Other things to note: When able, I plan on picking up some Lian-Li AL120's.
So that should cover everything. Feel free to offer suggestions across the board. I'm not married to any of the parts I listed. The only firm Manufacturer is AMD for the CPU. I will OC but not to an extreme, only to what is easily achievable without tweaking things for six hours.
I look forward to your suggestions. One last note, time line is also open. If there is data that suggests waiting a few months for better pricing, please provide it and I'll take that into consideration.
