- Feb 20, 2009
- Sacramento, Ca
Hello all, thanks for any help you can give me. First, here is a list of the hardware.
MoBo: GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD
CPU: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
GPU: ASUS EAH4350 SILENT/DI/512MD2(LP) Radeon HD 4350 512MB
HDD: Seagate Barracuda 7200.11 ST3160813AS 160GB 7200 RPM SATA 3.0Gb/s
PSU: Antec NEO ECO 400C 400W Continuous Power ATX12V 2.3 / EPS12V 80 PLUS Certified
Sound Card: M-Audio Delta 66 PCI sound card.
A generic case and DVD drive.
The computer installed Windows XP just fine and ran a few updates to the operating system. Then I updated all the drivers for the sound card, the GPU, and the MoBo.
My problem is that after not turning the computer on for a day, it won't start up. When I press the power button, it goes through the BIOS, then through a check screen, and gets to the Welcome screen then restarts. After doing this twice, it ran through a HDD check and came out clean. There were no problems. After completing the check, it restarted, got to the Welcome screen and then shut down again.
Could this be a heat issue? I am using the stock heatsink. Is the 400W Antec PSU enough? The GPU doesn't even need a power connector.
Please Help.
Thanks
Mike
Please Help.
Thanks
Mike
