- Dec 6, 2010
Well, the FX 8150 BD broke the world record for CPU speed at 8429 MHZ, if the 8150 can do that, the 8170 should blow the doors off the 8150
any link ?
The problem with these chips related to Folding as I understand it is without the minimum 8 threads you won't be picking up bigadv units, and I question whether its performance with regular units can make up for that shortcoming.
Didn't know that - I just remember hearing somebody here - Charles maybe, say it only had 4 something so it wouldn't be a serious player for folding. I was thinking it was a 6 core with only 4 alus or something of that nature.You will have 8 threads though. Its a 8 core cpu. Each module is made up of 2 cores. The 2 cores share some components but they are capable for running two independent threads. So we should be able to do bigadv with these guys.
How do they run bigadv with 6 cores and no HT?Phenom II X6's are already making the 3 day deadlines on bigadv; Bulldozer just evens the playing field with i7's. . .finally.
Is AMD going to equal the I7 in folding?
I hope it is better....ahh the days of amd and lower costs...
The Bulldozer has only 4 Floating Point Units. So eight FAH threads will have to squeeze through the 4 of them, just like on Intels i7 chips.
Bulldozer has 4 flexFPU's, meaning it has 8 FPU's similar to current x6's (128 bit), which is a 33% increase. The flexFPU, however, means that 2 fpu's in the same module can be combined for an effective 256-bit fpu if one of the cores is not using its own fpu.
I'll try to find a graphic for it but essentially bulldozer can do 8 seperate 128-bit floating point executions at a time, or 4 256-bit fp executions simultaneously.
Edit:
Here's a pretty good overviews, http://www.anandtech.com/show/3863/amd-discloses-bobcat-bulldozer-architectures-at-hot-chips-2010/4 . What will really be interesting is to see how aggressively AMD prices and clocks Interlagos, which is their server class bulldozer with up to 16 cores. Could make things pretty interesting for folding if the folding client runs well on the bulldozer architecture.
I’ve read that an 8 core Bulldozer can complete 4 256 bit operations per clock cycle. How many 32 bit operations can it complete per clock cycle? How many 64 bit operations can it complete per clock cycle?
