- May 30, 2004
- Folding@Home
AMD Catalyst™ 15.8 Beta Driver for Windows® Release Notes
Article Number: RN-WIN-15.8 BETA
AMD Catalyst™ 15.8 Beta for Windows®
This article provides information on the latest posting of the AMD Catalyst™ Software Suite, AMD Catalyst™ 15.8 Beta Driver.
This particular software suite updates the AMD Catalyst™ Display Driver and the AMD Catalyst™ Control Center. This unified driver has been updated, and is designed to provide enhanced performance and reliability.
Package Contents
The AMD Catalyst™ Software Suite, AMD Catalyst™ 15.8 Beta Driver contains the following:
AMD Catalyst™ Display Driver version 15.201.1151
Compatible Operating Systems
AMD Catalyst™ 15.8 Beta is designed to support the following Microsoft Windows platforms:
Windows® 10 (32 & 64-bit)
Windows® 8.1 (32 & 64-bit)
Windows® 7 SP1 or higher (32 & 64-bit)
Highlights of AMD Catalyst™ 15.8 Beta Windows Driver
This driver provides support for the Oculus 0.7 SDK on Windows 7, Windows 8.1 and Windows 10. More information on the Oculus 0.7 SDK can be found at the following link on the Oculus Developer site:
Performance Optimizations
Batman™: Arkham Knight - Performance and quality/stability updates
Ashes of the Singularity - Performance optimizations for DirectX® 12
Resolved Issues:
[424009] Adobe® Lightroom may crash if GPU rendering is enabled
[423336] Mouse cursor coordinates may be swapped on some 3x1 Eyefinity configurations
[421110] The Witcher® 3: Wild Hunt - Corruption may be observed when AA is enabled in AMD CrossFire™ mode
[424127] The Firefox browser may crash while opening multiple tabs (2 or more)
[425168] Anti Aliasing settings are not retained after Applying in the AMD Catalyst™ Control Center
[425156] System hangs when launching Call of Duty® - Modern Warfare 3 or Diablo™ III
[424776] Metal Gear Solid® : Ground Zero may crash when launched
[425421] Call Of Duty®: Black Ops III - texture corruption observed when launched in DirectX® 11 mode
[425452] Sword Coast Legends - FRTC settings are not activated in the game
[411945] Project CARS may experience corruption when AA is set to D2SM
[425382] A green screen may be observed on some "Llano"/"Ontario" APU's when playing video under Windows 10
[424330] Watch Dogs™ may experience flickering / corruption after changing game resolution
[425440] AMD HDMI® Audio is disabled after driver installation
[423013] F1 2015™ may experience flickering during gameplay or in game benchmarking
[422551] Call of Duty® - Advanced Warfare may freeze randomly when run in Quad CrossFire mode
[424168] Text corruption observed when using Windows 10 Mapp application
[424222] System may hang when installing the driver on a Windows 10 system with 2 or more GPUs
[424710] "Device being used by another application" error is displayed when attempting audio playback on Windows 7 systems
Known Issues:
[423924] Unable to create an Eyefinity SLS if one of the displays is a MST display device
[423759] Unable to apply Fill mode in Eyefinity if 2560x1600 and 2560x1440 resolutions are used together
[425484] DiRT Rally™ crashes during gameplay and benchmarking when launched in DirectX 11® mode on some BENQ 144HZ Freesync monitors
[425496] Mad Max - Color corruption is observed when Alt+Ctrl+Del is pressed followed by the Escape key
[422806] Battlefield™ Hardline crashes on pressing Ctrl+Alt+Del while running in AMD Mantle mode
[422674] Corruption may occur in DiRT Rally™ with CMAA enabled with Portrait SLS and AMD CrossFire™ mode enabled
[425417] Windows 10 driver installation may halt on some systems with an AMD 990FX chipset and AMD CrossFire™ enabled
As a temporary workaround, please uninstall the existing driver before installing the AMD Catalyst™ 15.8 Beta driver
[425432] Some BENQ 144hz Freesync monitors may lose the signal while uninstalling the driver
[425659] Assassin's Creed® Unity may experience minor frame stutter when AMD CrossFire™ mode is enabled
AMD Issue Reporting Form
This driver release incorporates suggestions received through the AMD Issue Reporting Form. To provide us with your feedback, visit the AMD Issue Reporting Form.
Release Notes & Download Links
