- Apr 21, 2001
- The North Pole
Yo all what´s up
I got a T-bird 1,33 [email protected],33(ayhja stepping). I´m not sure, but I think I´m running a bit high on cpu temp(55-58 low load). Overclocked to 1,4 Ghz 58-60. All Celcius.
The CPU cooler is a Alpha FC-PAL35(modified) with an 1.44w Y.S.tech fan.
NOW: Ok, it runs fair when not overclocked. It runs just as fine at 1400 Mhz, but freezes after some time(10-15 mins). I does boot at a lot higher speeds(1600+), but freezes shortly after booting.
Why it freezes at very high speeds I cannot tell, but it seems like cooling might be the issue to why it freezes at 1400 Mhz. Right?
The cooling needs to be changed if I want this baby to go beyond 1333Mhz, that is clear. But is there a way to tell the absolut maximum before investing in a high-end cooling system?
If it will do 1400-1466 with a better HSF, and about 1500 with water cooling, the choice is easy. If water cooling and a better memory module could give me up to 1700, it is worth considering.
IF i go watercooling, I would buy this: DangerDen Maze2+Senfu DualRadiator+Eheim 1046 or 1048.
C´mon, gimme all your $$ worth of opinions!
regards,
Henry.
regards,
Henry.
