I have you both beat 1980 red honda civic 2 dr where the paint was faded so bad it almost looked pink Just like this one, found this in google images, do you like my custom editing, I took the people driving out of the picture.
we had a number of those old three valve civics, we had to carry 2 spare intake valves and a gallon of water everywhere we took them.
water was to cool the fuel pump when it vapor locked and the spare intake valves were for when the swirl valve would carbon up and stick open.
it got to where we could do it all at a stop light in miami.
Was there ever anything done at a stop-light in Miami, that was considered odd or strange? Hehehe.
Why officer my fuel pump just wanted a little drink of water and my bud is under the hood trying to get the coke and carbon off the third valve. Okay son get 'em hands up we don't allow no coke down here, third valve or not.
RGone...ster.
I know we all got carried away and had some fun in the thread while you were gone. But we are here now in the process. We don't have enough information to give a valid guess as to what is going on with your setup. 4.3Ghz as you say and 1.425V (set in bios) seems a little high. BUT without the type of information shown as below, there is no way we can get any glimpse into what is happening at your end.
Prime 95 Blend running and HWMonitor (free version running) and toward and at the end of 20mins of P95 Blend, capture these 4 separate images as below and attach them to the forum or we actually may as well be carrying on our foolishness as before because of the lack of information to point to what to do. Luck man.
RGone...
A good post showing 3 cpuz and HWMonitor. We can read them for clarity.
mjrhealth, posting your specs isn't really relevant to the OP in order for us to help we need to know the information that has been requested of the OP. This statement "NB Freq Multi X 10 No need to go higher there is no advantage with these chips" isn't accurate either.My Settings
CPU Freq - 212
Spread Spec - Disabled
Multi/Volt control - Manual
CPUMulti - X21.5
CPU V - 1.4375V
CPU NB Volts - 1.1875
HT Bus Speed - 2121 ( X10)
HT Bus Width - X16
CPU load line Calibration - disables( recommended crashes when on)
Cool and Quiet is on seems to be ok
+1 to Manny the NB makes quite a difference. Certainly if you have the Ram speed to use it!
Don't be asking Drake nothing about no 1866 ram. He has a ram issue.
RGone...
