IMO if you're failing p95, you're not stable. I don't have experience with your chip, but I need 1.45v(1.48 loaded) to hit 4.8ghz and pass 2 hours of blend with my 8350. If one core consistently failed you're close to required voltage, if one core or the other in a module fails you may have reached a "limit" where more voltage won't help stability, if cores randomly fail across all modules you're nowhere near the voltage required for stability. Also, I'd put the stock AMD fan on the vrm heatsink. Put the corsair 120 on the backplate and plug in into a fan header that that allows you to switch it on and off, I'd bet you'll notice the stock CPU fan is doing the bulk of the cooling as its cooling a much more localized spot. And lastly your socket and core temps are a little higher than I'd be comfortable with, especially if you're not using p95 to test for stability. 72c@socket, 62c@core.
