Rapha (Dec 24, 2000 11:48 a.m.):
Don't know this mobo. But it doesn't matter.
First step :
You only have to increase clock multiplier to 5.5 and increase voltage from stock 2.2v to 2.3v or 2.4v to keep it stable.
Caution : you must have proper cooling. Standart heatsink and fan can't do the job.
Using thermal paste in place of the thermal pad is necessary to have a good thermal transfer between CPU and heatsink.
Case cooling can help too : add case fans for having a good air flow inside the case.
Second step :
If your mobo has settings for FSB > 100 and if you can get your system stable at 550, then you can try 5x112 = 560. This will give performance near to 6x100 (with 2x=6x remapping)
If you wan't to overclock it a bit more, you can apply lapping to CPU and heatsink to enhance thermal interface.
Don't expect to break the 600 limit. It is possible but it's a big challenge.
