@Gopher - what are your temps with those settings?
Where is it showing up as 666?
Because you have to remember that DDR is Double Data Rate, so 666*2=1332 which is close enough to 1333. If you want it at 1600, then go ahead and set it there.
The M4A79T says it supports 1600 MHz RAM, but that's an OC, so you may need a slight voltage bump to make it work (DRam voltage)
SuperPI 1.5 ver testing 16k, 1m, 8m
- 200hz x17 (1:2 ddr 800) 6 ras to cas
.187s, 20.623s, 4m 25.031s
- 200hz x17 (1:4 ddr 1600) 11 ras to cas
.187s, 20.436, 4m 13.635
CPU/NB Voltage - AUTO
CPU VDDA Voltage - AUTO
NB Voltage - AUTO
There is no actual FSB. It's a number, just a number
