Hey guys! First let me say my GPU is a day early and will be hear any moment.
Excited is an understatement.
I have aftermarket cooling heatsinks on my lower 2 NVMe drives they stick out as they use heatpipes. But they are 3 and 4th GEN drives so they dont get very hot. id have to go back to my mobo heat spreader which
I use a Mustek case a Lian li copy.
https://www.amazon.com/dp/B0CP7SQ58Z?ref=ppx_yo2ov_dt_b_fed_asin_title Yes i have 12 120mm fans as i went push/pull on my AIO and id loose two from the bottom.
My biggest issue is it blocks my Cmos battery making it hard to reset the bios after a failed ram overclock.
Ive had my ram up too 6600Mhz CL32 but i was just playing around. ATM im at 6200Mhz CL30 and tight timings with no additional voltage. I did a RAM benchmark and a disk benchmark and with both i scored in like 97-99% fastest scores recorded. So im on the right path to have fun. Boots into windows in like 12 seconds, Ill need to time that. Plus my game drive has 6 games on it and ready to play.
Before i forget do i need a video cable to use over the HDMI cable on my VGA?
Also anyone have a suggestion on a sound system i just need a 2.1 ?
