Nugget1800X
- Oct 31, 2017
Hi guys been tearing my hair out for months!
My build is:
RYZEN 7 1800X Running @4.1Ghz Stable
32 GB Ripjaws V (2x16Gb) @2666 trying for rated speed of 3200Mhz Timings: 16-18-18-38 2N (Dual Rank Hynix it seems) Model # F4-3200C16D-32GVK
I've watched every video and forum humanly possible over the past 3 months in relation to my Ram and no one seem to be able to hit the rated speed of 3200mhz let alone higher with tight or loose timings.
The best they can get is 2666Mhz which I am currently running (stable)
Can anyone help me with working timings ohms and voltages on an MSI Pro Carbon X370 Motherboard for my RAM: Ohms, Voltages and Timings please to get this stable at the rated or above speeds yeah?
Full instructions would be invaluable too please, as I'm a first time RAM Overclocker. (Aside from XMP easy setups in past on Intel systems without any issues.)
Please don't say: "Just buy Flare X 3200Mhz 16gb kit" I do video editing and heavy gaming and want this system running as fast as possible with my current Ram as I can't afford more. (I live in Australia and everything here is super expensive so please can you do your best for me please!?)
For Example: https://www.mwave.com.au/product/gs...z-memory-ab69563#detailTabs=tabSpecifications
If you can give me timings and other settings for 3200Mhz that are stable excellent! If you can get me higher speeds up to 3600Mhz stable I'll be forever grateful!!
Here's to hoping someone has an answer for me!
Fingers crossed!
My build is:
Fingers crossed!
