Thanks, will try as well. But in pubg yesterday i believe I saw more dips/stutters than usual. My temps were crazy low in 52 max. How come my volt became 1.1 max? I did set my vddcr cpu voltage to 1.2.
The voltage only affects stability and temperatures, not performance, except that lower temps can keep one higher in the turbo mode range for longer. But make sure with lower voltages you stress test thoroughly.
Thanks. But Even if i change voltage to 1.25 or something the Max voltage in ryzen master states 1.1. Do anyone know how i raise it to 1.2? Some other values contradict the cpu voltage?
